I got the Spi out of storage the other day and drove it around to the house without any problem other than the fact it was idling at 1700 rpm. Today I tried starting it to figure out what is wrong but it wont start now.
When I turn the ignition on I hear the fuel pump prime then stop but when I start the car it fires up then immediately cuts out. If I then start the car a second time it just turns over and doesn't fire. I don't here the pump prime either. If I leave it for a few minutes I can hear the fuel pump prime and it goes through the same procedure again. It fires momentarily, cuts out then wont start.
I have a code reader and I have found one fault code (coolant sensor) and an ambient temperature reading of 200 degrees.
Can anyone suggest what I can try or what the issue might be?
