I've recently fitted a maniflow medium lcb and 1.75" twin box exhaust. I also fitted a minispares torquemaster inlet. I fitted these parts to ready the car for 1275 I'm rebuilding and the car currently still has its 998 which was running like a swiss watch until I fitted the above parts.
However the car bogs down now under acceleration. Am I right to assume a different needle is required? And also which needle would people in the know recommend? I just need to get the mini running nicely until the new motor is ready. Still on standard airbox and filter.
Cheers in advance
Rich
Needle Reccomendation
Superdeluxe
, Apr 03 2020 03:48 AM
9 replies to this topic
Posted 03 April 2020 - 03:48 AM
Posted 03 April 2020 - 07:08 AM
Aau was good for me not perfect but close enough
Posted 03 April 2020 - 11:08 AM
AAU is well suited for 998 with stage 1 kit or a little bit richer is AAA
Posted 03 April 2020 - 11:12 AM
Get an AAA and also check for manifold leaks and also Re top up the dashpot oil. See if that helps.
Posted 03 April 2020 - 05:43 PM
It's all good for leaks and vac advance seems to be working. Will get a AAA needle ordered.
Cheers for the advice
Posted 03 April 2020 - 06:06 PM
AAA ran too rich. AAU was perfect for my stage 1 setup
Posted 04 April 2020 - 04:55 PM
I had the same set up and the same issue with blogging down. I stuck an AAA needle in there and it sorted everything out. No bogging and plenty of go.
Posted 09 April 2020 - 06:09 PM
Nice one. Just waiting for the AAA needle in the post.
Posted 14 April 2020 - 02:44 PM
AAA needle went in this afternoon. Runs like a dream. Very potent considering it's a 998. Just need lock down to ease up now so I can send the 1275 gt block off for machining!
Posted 14 April 2020 - 05:50 PM
Go to the MOT Centre to see if you can get an emissions readout.
Edited by cal844, 14 April 2020 - 05:51 PM.
