Best Primer
8 replies to this topic
#1 Wreckitralph1
Wreckitralph1
    Formally known as wreckitralph
  • 127 posts
Posted 03 April 2020 - 08:33 PM
what primer are you guys using to keep suface rust at bay whilst  in storage or generally not being worked on  i can get to the insides of all maor front end panels at the moment so would like to strip back to the metal and get it in primer has to stick well ect i  was looking at buzzweld or raptor epoxy
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,885 posts
  • Name: Neil
Posted 03 April 2020 - 08:50 PM
A Epoxy primer is best, its water resistant.
#3 Avtovaz
Avtovaz
  • 1,132 posts
Posted 03 April 2020 - 10:01 PM
yes the epoxy stuff is good., i use hp body 989, you can if you want roller it on save spraying it.
#4 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 03 April 2020 - 11:42 PM
realy lol ? if thats the case would be great for the hidden ares inside boxes and channels
#5 Gcal
Gcal
  • 124 posts
Posted 04 April 2020 - 08:07 AM
I found this halfords stuff to be quite good and well rated https://www.halfords...0ml-331980.html
#6 sonscar
sonscar
  • 2,720 posts
Posted 04 April 2020 - 02:38 PM
Epoxy is very good but if you recoat it outside the window I find that subsequent coats have variable adhesion unless you abrade it.This may be a problem in inaccessible areas.Steve..
#7 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 04 April 2020 - 05:49 PM
fair point steve something worth thinking about for sure
#8 blakie
blakie
  • 1,029 posts
Posted 05 April 2020 - 06:57 PM
I'm looking at doing the same to my shell as I treat some surface rust areas.
Did I read on another post somewhere to use zinc primer? I'll uses epoxy also if this is best.
#9 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 05 April 2020 - 08:32 PM
i have zinc rich primer on any mating faces/panel joins
