Beige, Beige Or Beige?
Posted 05 April 2020 - 01:07 PM
I’m trying to sort my engine bay out while we’re in isolation and am having difficulty finding out what colour my car is. I’ve got a 1971 mk3 850 and I suspect it is/was either Bedouin or El Paso Beige, but no paperwork to confirm this. Pic of the car:
DBC2AA7C-476C-4274-B432-A2D65F100A5B.jpeg 111.46K 5 downloads
4E217AB0-43F2-4846-B987-B3B269D4DF17.jpeg 50.81K 6 downloads
I looked on the forum and this post by rich_959 was helpful!
http://www.theminifo...70#entry3617059
However in 2013 it had some bodywork done and a respray and I have invoices for Pale Brown N6/N549 Standofleet HS Mix plus thinners and hardener. I’ve found the paint: http://standowin.sta...etail?id=489493
Question is who do I order from? I only want a rattle can as I don’t have any equipment for a proper spray job.
Any help appreciated! Alex
Posted 05 April 2020 - 01:15 PM
Hard to tell without bright sun light, but that is either bayge or baij.
Posted 05 April 2020 - 03:33 PM
Posted 05 April 2020 - 04:01 PM
OK, perhaps this is more useful.
I found long ago that it is all rather dark, down behind the engine, so I paint at least the inside of the subframe and below the subframe bulkhead, WHITE.
Posted 05 April 2020 - 04:14 PM
You should be able to go to any paint supplier (not Halfords ect, but proper car paint supplier), and if you have the paint spec, which you seem to have by the receipt description, you can just ask them for a rattle can and they will make one up for you to your spec. I see that you have a Movac store near you, they should be able to help?
Posted 05 April 2020 - 04:31 PM
Edit: Just seen this below is already in your link
Mk3 Paint Colour & Trim Details:-
http://mk1-performan... MK3 Models.pdf
Edited by mab01uk, 05 April 2020 - 04:38 PM.
Posted 05 April 2020 - 05:51 PM
I’d say bedouin
http://mk1-performan...paint_chips.htm
Edited by steeley, 05 April 2020 - 05:52 PM.
Posted 05 April 2020 - 09:55 PM
Neet Street appreciate your advise on the paint shop that’s really helpful as I’d have probably just tried Halfords!
Will give Movac a call.
Posted 05 April 2020 - 10:00 PM
