It was at the bottom of their page. Very easy to find.
Setting Up And Adding New Adjustable Front Suspension
Tonylamb
, Apr 06 2020 03:57 PM
suspension
18 replies to this topic
#16
Posted 06 April 2020 - 08:44 PM
#17
Posted 07 April 2020 - 10:50 AM
So it was, I was just lazy and did a search and it never came up... Should have just flicked thru the tech section. ?It was at the bottom of their page. Very easy to find.
#18
Posted 10 April 2020 - 09:16 PM
So I've got the adjustable lower arms in place and the circlip on the inner pot joint. Couple of problems to sort out. The tracking is obviously way off confirmed by a spin down the road this afternoon. I set the lower arms a few milimeters longer than the standard arms so there should be a smidge of negative camber over the previous set up. Question is do you set tracking first then camber then camber or camber first then caster???? In other words there must be an order of which to set first.
The next problem is that I've put the new superlite wheels on the car and they clearly have more offset. Which makes them unfortunately wide enough to foul the wheel arch on full lock. Does the increased camber also increase the caster and therefore push wheels forward?
#19
Posted 10 April 2020 - 11:33 PM
there is no order as changing one thing changes the others. you just have to work your way through many times till it is right.
the wheel offset is what is causing the catching along with the ride height.
please note setting the corner weights correctly will also affect the suspension angles. so really get suspension about right. set corner eights then correct the suspension. then trim the bodywork to suit the wheels and tyres fitted.
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
