Breaking, 1995 Mayfair. All Available
32 replies to this topic
#1 Mikey205
Mikey205
  • Just Joined
  • 15 posts
  • Local Club: Midlands
Posted 10 April 2020 - 08:34 PM
Breaking our 1995 Mayfair in BRG.
Shell has had a complete front end replacement inc. genuine inner wings, outers, front panel and scuttle replacement. Front of floors were patched to inner wings, not pretty but very solid.
Requires the rear end sorting and the n/s door step replacing
£500 with tags and v5.
SPI fuel injected 1275. Rebuilt top end Inc ground valves, slight skim, stem seals etc. New water pump, thermostat, coreplugs and associated gaskets on diff Inc shaft seals. Block was completely cleaned internally then head and block painted red. Sump and box etc painted silver. Rocker cover painted satin black.
Can come with SPI inlet and exhaust manifolds, both cleaned and painted at extra cost.
Engine ran as sweet as a nut and drove fantastically well. £700.
Good condition front subframe. Surface rust only, £100.
Rear subframe. Good condition Inc radius arms but they need overhauling ideally
Has rear brakes with new cylinders and shoes, £200
Front hubs inc. new brakes, decent bearings and painted calipers £60
I've also got a complete SPI cars worth of parts, silicone hose kit in black, almost everything in the engine bay was reconned, cleaned or painted. Please ask for anything you may require.
I'm happy to sit on items for people with a small holding deposit until lockdown is done with. Obviously collection only on bigger items but I maybe able to post smaller items. Collection from Redditch, Worcestershire.
Mike
Edited by Mikey205, 10 April 2020 - 08:39 PM.
#2 Jonesy77
Jonesy77
  • 67 posts
Posted 10 April 2020 - 09:15 PM
Mike
Any pictures
#3 Mikey205
Mikey205
  • Just Joined
  • 15 posts
Posted 10 April 2020 - 09:40 PM
http://imgur.com/a/sD3Xitl
#4 muzzy
muzzy
  • 33 posts
Posted 14 April 2020 - 08:33 PM
hi mikey is the engine available?if so if its ok with you id like to buy it.
Edited by muzzy, 14 April 2020 - 08:36 PM.
#5 Jonesy77
Jonesy77
  • 67 posts
Posted 15 April 2020 - 01:32 AM
Carpet set+
#6 Mikey205
Mikey205
  • Just Joined
  • 15 posts
Posted 20 April 2020 - 10:51 AM
Carpet set+
Ive got a black mpi carpet if thats of interest?
Mike
#7 Jonesy77
Jonesy77
  • 67 posts
Posted 20 April 2020 - 02:00 PM
Carpet set+
Mike
Is it cheap? Lol
I got the section I needed but would be. Open to a cheap replacement set
#8 Mikey205
Mikey205
  • Just Joined
  • 15 posts
Posted 20 April 2020 - 04:23 PM
£100 but ill chuck in a new set of floor mats and underfelt from minispares
#9 Lucas1988
Lucas1988
  • 406 posts
  • Local Club: Frome Mini Club
Posted 23 April 2020 - 01:00 PM
Carpet set+
Mike
Have you got some photos of the mpi carpet, is it the one for over the cross member?
#10 wassupcrew
wassupcrew
  • 502 posts
Posted 23 April 2020 - 08:36 PM
Do you have a three clock dash?
#11 Mikey205
Mikey205
  • Just Joined
  • 15 posts
Posted 24 April 2020 - 02:42 PM
Both the clocks and carpet are sold. Thanks
#12 Homersimpson
Homersimpson
  • 802 posts
Posted 25 April 2020 - 08:43 AM
I'm interested in the shell if still available, are you able to deliver it within Redditch (i'm up in Webheath?).
#13 Mikey205
Mikey205
  • Just Joined
  • 15 posts
Posted 28 April 2020 - 05:52 PM
Shell is back available after being messed around. Not sure if Ebay links are allowed but here it is on ebay:
https://www.ebay.co....tm/153912010034
Edited by Mikey205, 28 April 2020 - 05:53 PM.
#14 wassupcrew
wassupcrew
  • 502 posts
Posted 28 April 2020 - 07:07 PM
Do you have the headlining rod with the red ends the one nearest the front just broke one of the ends fitting my headlining
#15 Mikey205
Mikey205
  • Just Joined
  • 15 posts
Posted 29 April 2020 - 06:43 PM
The headlining is still in the shell and thats where it is stopping! Lol. Sorry.
Mike
