Somethings Missing
Best Answer nicklouse , 15 April 2020 - 03:36 PM
You are missing the trigger wheel at least maybe other bits depending on what it actually is. Go to the full post
12 replies to this topic
#1 Jonesy77
Jonesy77
  • 67 posts
Posted 15 April 2020 - 02:41 PM
Hey all
I got this today well awaiting on it. But I believe there is a part missing black possibly magnet?
Am I right in thinking this is all I need to fit an electronic ignition instead of current points?
I have searched online and forum and various kits with more bits than others available so not 100 % what I need
#2 Jonesy77
Jonesy77
  • 67 posts
Posted 15 April 2020 - 02:43 PM
This is my current distributor
Car hasn't been starting for a while and I'm going to redo alot of wiring checking earth parts etc so may as well fit electronic now before I try and restart it
#3 Its a min
Its a min
  • 284 posts
Posted 15 April 2020 - 03:35 PM
Where did you get it from? It depends on what make it is.
Some have spacers which fit under the rotor arms and some have trigger rings but it depends on supplier/manufacturer.
Remember also that you may need to change the coil for one suited to electronic ignition.
Edited by Its a min, 15 April 2020 - 03:36 PM.
#4 nicklouse
  • 17,945 posts
Posted 15 April 2020 - 03:36 PM   Best Answer
#5 Jonesy77
Jonesy77
  • 67 posts
Posted 15 April 2020 - 03:39 PM
Bought it off someone off a mini Facebook page. Paid for it prior to finding out a piece was missing. I am hoping someone may have a spare piece who has maybe broke a mini with one?
#6 Jonesy77
Jonesy77
  • 67 posts
Posted 15 April 2020 - 03:40 PM
Can these be bought separately?
#7 Its a min
Its a min
  • 284 posts
Posted 15 April 2020 - 03:45 PM
That one looks like it may be a Powerspark kit minus the trigger.
https://simonbbc.com...yl-distributor/
You could try calling them.
Edited by Its a min, 15 April 2020 - 03:46 PM.
#8 Jonesy77
Jonesy77
  • 67 posts
Posted 15 April 2020 - 03:47 PM
Looks like it's not even right for my 88 Mayfair 998. Oh goodness
#9 Its a min
Its a min
  • 284 posts
Posted 15 April 2020 - 03:51 PM
Quite possibly. 88 Mayfair probably has a 45 or 59 dizzy but you need to check. If it is, you'll need this kit.
https://simonbbc.com...9d-distributor/
Are there any markings/serial numbers on the module? If so, give Simon a ring and check. It may still work.
Edited by Its a min, 15 April 2020 - 03:53 PM.
#10 Jonesy77
Jonesy77
  • 67 posts
Posted 15 April 2020 - 03:54 PM
That's great
I'll have to stick that one on ebay see if I can get a few quid back then.
#11 viz139
viz139
  • 569 posts
  • Local Club: Irish Mini Owners Club
Posted 15 April 2020 - 10:38 PM
Or could be this one
https://www.mm-4x4.c...-kit-2721-p.asp
Most of the conversion kits are designed to work with standard coils .
#12 Jonesy77
Jonesy77
  • 67 posts
Posted 16 April 2020 - 01:50 AM
Hopefully when it comes I can read a code off it to find out
#13 Its a min
Its a min
  • 284 posts
Posted 16 April 2020 - 01:29 PM
The connectors and grommet on the one you bought definitely look like a Powerspark piece of kit rather than the Britpart.
