1275 Gt - Metro Turbo 1310 Engine Project
114 replies to this topic
#16 Bdshim
Bdshim
  • Just Joined
  • 196 posts
Posted 02 May 2020 - 06:43 AM
Great work, great project ?
#17 eric67
eric67
  • 128 posts
Posted 02 May 2020 - 08:03 AM
Looks like a great project and I like your plan to only use original Austin / Rover parts. I presume there is plenty of room under the bonnet for all the extra turbo kit?
#18 MikeRotherham
MikeRotherham
  • 1,030 posts
Posted 02 May 2020 - 09:23 AM
Did you get some of the parts like the distributor vacuum unit passivated or is it paint? Looks great either way.
#19 DeanP
DeanP
  • 499 posts
Posted 02 May 2020 - 09:40 AM
Nice
#20 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 02 May 2020 - 11:04 AM
Engine and Cylinder head
This Part I have not done myself. Andrew Collinson [Retro Minis] took care of most of this work. I will be doing some more with this next week. Hopefully join engine and box together, check compression ration, paint block, replace core plugs and more probably -
Its had all the usual work, but keeping it almost standard. First pictures are the engine when i first got it - then how it currently looks
Attached File  Metro turbo engine.jpg   51.92K   1 downloads
Attached File  13.jpg   31.52K   1 downloads
Attached File  15.jpg   34.76K   2 downloads
Attached File  08.JPG   40.29K   1 downloads
Safely stored in the wardrobe for some years now
Attached File  Block pistons all up.jpg   52.25K   1 downloads
Attached File  BK 450 head gasket.JPG   35.98K   0 downloads
Attached File  Head face.jpg   55.25K   0 downloads
Attached File  Head face close.jpg   54.68K   0 downloads
Attached File  3 Angle seat.jpg   43.24K   0 downloads
Attached File  Head top with seals.jpg   43.72K   0 downloads
Attached File  Bore Hone finish.jpg   41.66K   0 downloads
Attached File  Crank CAM6581.JPG   44.75K   0 downloads
Attached File  Engine all built clutch end.jpg   58.67K   0 downloads
Attached File  Engine all built.jpg   58K   0 downloads
#21 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 02 May 2020 - 11:12 AM
I have to use the bulk head box to allow room for the turbo but as it was used on ERA turbo i am happy with the change. But i should have plenty of room .. I hope
#22 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 02 May 2020 - 11:15 AM
I kept searching for info on the correct vacuum unit. Once it was identified I managed to find NOS on ebay. Cleaned the body of the distributor with thinners to remove most debris then clutch and break cleaner. New rotor arm and new cap fitted. I have not replaced the module yet but not certain i will use this one. always nice to have the option.
#23 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 02 May 2020 - 11:21 AM
The entire car should be original Austin / Rover parts when complete. Not going to give away the final look of the car yet but have the interior, wheels, arches, dash, all original parts. All from different years of cars but all original. Plan is to complete the engine build in the next couple of weeks. Wrap it up - place in my garage storage for safe keeping. Along with all other refurbed parts. Then move on to the shell.
#24 mini13
mini13
  • 3,811 posts
Posted 02 May 2020 - 11:39 AM
I would swap to a Gt17 turbo and fusion fabs manifold to avoid cutting the bulkhead.
#25 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 02 May 2020 - 12:22 PM
I know there are many options to avoid the bulkhead mod. But they did it to ERA turbo and my plan is to use only original parts where possible.
#26 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 02 May 2020 - 12:28 PM
Plenum Chamber
Still waiting for top coat paint but have now made the gasket and primed it ready.
Attached File  IMG_1132.JPG   39.64K   0 downloads
Attached File  IMG_1133.JPG   52.87K   0 downloads
Attached File  IMG_1134.JPG   45.66K   0 downloads
Attached File  IMG_1135.JPG   42.47K   0 downloads
Attached File  IMG_1136.JPG   38.3K   1 downloads
Attached File  IMG_1137.JPG   46.62K   0 downloads
Attached File  IMG_1138.JPG   34.25K   0 downloads
Attached File  IMG_1139.JPG   49.3K   0 downloads
Attached File  IMG_1144.JPG   49.68K   1 downloads
#27 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 02 May 2020 - 12:34 PM
59DM4 Distributor
This is a NOS distributor that i managed to find. Took a long time to find the correct module to use with this. From what i have researched the coil should also be OK. Standard original plugs and new leads. I did replace the distributor cap as the original had a small crack.
Attached File  IMG_1141.JPG   65.17K   1 downloads
Attached File  IMG_1142.JPG   62.83K   1 downloads
#28 MikeRotherham
MikeRotherham
  • 1,030 posts
Posted 02 May 2020 - 04:09 PM
Love the attention to detail and the refurbishment of old parts.
I have used a similar idea on my car to only use original parts if possible or when I have planned an upgrade to only use parts from the BL/ Austin/ Morris /Rover corporate parts bin. Considering the range of cars they produced over the years there's plenty to go at.
#29 MikeRotherham
MikeRotherham
  • 1,030 posts
Posted 02 May 2020 - 04:38 PM
Have you had to refurbish any plastic parts and what did you use?
Currently trying to clean up bits of the fresh air system. The air scoop that resides in the engine compartment behind the grill and the air pipe under the drivers side wing.
Trying to remove underseal from said parts. WD40 used to remove the underseal and leave a nice shiny coated surface. I think its been 'improved'* and now just leaves the plastic dull.
Any suggestions?
Edited by MikeRotherham, 02 May 2020 - 04:43 PM.
#30 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 02 May 2020 - 05:57 PM
Any suggestions?
The filter housing was in poor condition and im still not happy with it really, clock set was not the best. I tried the autosol in a small area and removed scratches but left dull finish. Mainly cleaned with hot soapy water. If i find a good solution i will post it.
