any thoughts on adding an intercooler, maybe you could find one from a Montego/Maestro turbo
1275 Gt - Metro Turbo 1310 Engine Project
#31
Posted 02 May 2020 - 06:06 PM
#32
Posted 03 May 2020 - 08:53 AM
#33
Posted 07 May 2020 - 08:54 PM
HIF44 carb rebuild
IMG_1150.JPG 48.21K
5 downloads
IMG_1156.JPG 34.72K
1 downloads
IMG_1162.JPG 45.46K
1 downloads
IMG_1185.JPG 53.41K
1 downloads
IMG_1200.JPG 41.38K
2 downloads
IMG_1201.JPG 44.26K
1 downloads
IMG_1202.JPG 44.44K
1 downloads
#34
Posted 07 May 2020 - 08:58 PM
I appriciate the staying with BL parts in a period resto way, very cool!
a couple of thoughts, what are you doing for the fuel tank/ feed for the turbo setup? and also for the echaust?
#35
Posted 08 May 2020 - 07:10 AM
will be using a SPI tank with built in pump. Still original Rover. Nice and tidy and believe its up to the job. Exhaust is a challenge and will most likely be Maniflow. Already got the tank and the down pipe.
#36
Posted 08 May 2020 - 08:55 AM
Yep spi tank and maniflow are ideal.
#37
Posted 08 May 2020 - 10:48 AM
No its a 1275 GT .. Taking a day off today and just cracked open the first beer. Starting tomorrow its rebuild gearbox and diff time ..
#38
Posted 10 May 2020 - 08:56 PM
X pin diff
Bit slow getting going with the diff and gearbox due to large hangover. Diff done today. Some confusion regarding torque setting for final drive gear but thanks to some advice happy to use 60lbf.
IMG_1209.JPG 47K
1 downloads
IMG_1212.JPG 39.03K
2 downloads
#39
Posted 17 May 2020 - 08:22 AM
Gearbox - Continued
In the previous gearbox section it was stripped cleaned and ready for build. Now its almost complete. All clearances checked and set as per Haynes manual - all torques used from manual - comp baulk rings - comp lay shaft - all new bearings - reused all original gears - gear oil used on assembly - 4 pin diff fitted with 3.44 FD
IMG_1228.JPG 40.87K
6 downloads
IMG_1231.JPG 45.69K
3 downloads
IMG_1233.JPG 45.69K
2 downloads
IMG_1236.JPG 55.61K
0 downloads
No special tools were used for striping or assembling. only whats in my garage. To install the new springs and ball bearings into the syncro hub i used a cable tie. Worked really well.
IMG_1237.JPG 34.13K
1 downloads
IMG_1242.JPG 46.51K
0 downloads
IMG_1260.JPG 45.01K
0 downloads
IMG_1264.JPG 41.92K
0 downloads
IMG_1265.JPG 51.33K
1 downloads
IMG_1266.JPG 46.21K
4 downloads
IMG_1267.JPG 49.76K
3 downloads
#40
Posted 18 May 2020 - 08:37 PM
Hif44, Inlet and Plenum chamber Continued
Finally got nearly all parts done and assembled inlet, carb and plenum. Still waiting on new dash pot spring and needle for the carb. But its all together at last
I still need the Non return valve for the inlet manifold if anyone knows where i can get one?
IMG_1277.JPG 47.43K
0 downloads
IMG_1278.JPG 46.15K
0 downloads
IMG_1279.JPG 46.22K
1 downloads
IMG_1280.JPG 39.4K
1 downloads
#41
Posted 19 May 2020 - 05:10 AM
#42
Posted 19 May 2020 - 05:40 AM
Im finding with most of the work so far is, a lot of cleaning, some basic repairs and service kits, then all the parts look new. Hope the engine is complete in the next 2 weeks then i can start with the panel replacement.
I just hope all these bits work when I finally get to test it
#43
Posted 19 May 2020 - 09:37 AM
Wow, an amazing collection of parts, attention to detail is spot on. Do you have any pics of the car? Couldn't see any.
Keep up the good work.
#44
Posted 19 May 2020 - 10:17 AM
Thanks. The car is in the garage behind all the boxes. My profile pic is an old picture from when i first got it. I will add some pictures of the car when i start the body work. But i have to be honest there is not much left of it. Front end removed - boot floor removed - sections of the floor removed. I started it years ago - stripped and chopped off front - then due to many reasons left it for years - then cut some more rust off and now finally have all new panels to complete. Just a case of doing it.
#45
Posted 24 May 2020 - 01:45 PM
So my plan to complete the engine this week has been ####ed right up.. Brought the block down from safe storage in the wardrobe :)
Started to remove some parts to prep for painting to find i was not happy with so many things. Main bearings not replaced - cam bearings not replaced - bent pushrods - cheap quality Rolon chain - cheap or old cam followers - the list goes on.. This was all supposed to have been done. Now it looks like i will do the work myself. I have contacted the guy that did the work and he apologises and can not explain what has happened. He promises to ship the parts required for the completion this week. Until parts arrive i can only paint a few more bits and wait...
