Rookie Question
2 replies to this topic
#1 beardylondon
beardylondon
  • 1,809 posts
Posted 14 May 2020 - 05:14 PM
Going to bleed brakes, but my ez bleed is elsewhere.
I have a bit of 5mm (Internal size) tube for rear brakes.
Question what is the perfect size for front bleed nipples on a disc braked car, 7mm internal diameter seems about right, can someone confirm?
#2 nicklouse
  • 19,067 posts
Posted 14 May 2020 - 05:16 PM
Not easy to answer as there are more than one size used on the front (and rear) depending on the producer.
#3 beardylondon
beardylondon
  • 1,809 posts
Posted 14 May 2020 - 06:36 PM
seems to be a 7mm nipple, but obv the end of the nipple is 8mm, hence my question as may need 8mm pipe?
Edited by beardylondon, 15 May 2020 - 08:04 AM.
