Need Help Identifying These
Best Answer nicklouse , 18 May 2020 - 12:30 AM
what manual do you have?
Haynes manual chapter 11 image 3rd page described section 9:16 mentioned in the words no images. but there is only one available space under the top arm that it would fit.
Go to the full post
9 replies to this topic
#1 Ruth's Mini
Ruth's Mini
  • 104 posts
Posted 15 May 2020 - 09:56 PM
I didn't have these parts labelled  :(  and hope someone can tell me what they are. They were stored in the same bag so I'm assuming they go together.
thanks in advance,
Brian
  • Attached File  13.jpg   144.66K   2 downloads
#2 KTS
KTS
  • 2,490 posts
Posted 15 May 2020 - 09:58 PM
Front suspension rebound rubbers, but missing the rubber parts ?
#3 Tupers
Tupers
  • 4,176 posts
Posted 15 May 2020 - 10:00 PM
They are what’s left of the rebound buffers that sit under the top arm and the front bump stops.
They should have rubber on them so are basically scrap now.
#4 nicklouse
  • 19,066 posts
Posted 15 May 2020 - 10:08 PM
all here
http://www.minispare...on~.aspx?1~8~66
#5 Ruth's Mini
Ruth's Mini
  • 104 posts
Posted 15 May 2020 - 10:19 PM
thanks everyone  :highfive:
#6 Tim the Fireman
Tim the Fireman
    Starting My Mini Up
  • 3 posts
Posted 16 May 2020 - 12:31 PM
Its worth noting, if you've lowered the front at all, to put a 1/8" shim under the rebound buffer. This helps to prevent ball joint failure due to excessive droop. You have two ready made shims there.
#7 nicklouse
  • 19,066 posts
Posted 16 May 2020 - 12:36 PM
That is actually more to do with neg camber.
#8 Ruth's Mini
Ruth's Mini
  • 104 posts
Posted 17 May 2020 - 11:48 PM
Following up on this does anyone have a picture of the "under top arm re-bound buffer" (2A4267) mounted to the car? My manuals don't show it.
Attached File  image.jpg   10.19K   0 downloads
#9 nicklouse
  • 19,066 posts
Posted 18 May 2020 - 12:30 AM   Best Answer
Attached File  08BA4393-A94D-4CC8-922A-701E15BE70B5.jpeg   336.67K   0 downloads
Edited by nicklouse, 18 May 2020 - 12:57 AM.
#10 Ruth's Mini
Ruth's Mini
  • 104 posts
Posted 18 May 2020 - 02:26 PM
thanks so much...
