Cannot Get Firm Brake Pedal Even After Bleeding.
8 replies to this topic
#1 Paul542
Paul542
    Just On Tickover
  • 6 posts
Posted 16 May 2020 - 06:34 PM
Just fitted a front disk brake conversion to a 1974 mini.
Got everything in place. bled the brakes startting from the back to the front, did it the old fashoined two person Crack, push, close, release way. No more air coming out but the brake pedal still wont firm up (it feels like standing on a clutch pedal).
Can't see any leaks anywhere.
I just don't know where to look next.
Anyone got any ideas what could be causing this?
#2 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 16 May 2020 - 06:38 PM
Does the pedal firm up if pumped rapidly?
If so hold the pressure on then crack the nipple, give it 10 pumps then hold down to tighten the nipple. Top up the reservoir then repeat on next corner.
Are the bleed nipples to the top on the calipers?
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 16 May 2020 - 06:40 PM
Calipers fitted correctly with bleed nipples at the top.
#4 Paul542
Paul542
    Just On Tickover
  • 6 posts
Posted 16 May 2020 - 06:46 PM
Cal - no the pedal does not firm up if pumped
Yes the calipers are fitted with the bleed nopples at the top
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 16 May 2020 - 06:55 PM
Ok, what to do now is to crack the unions from the master cylinder, then pump the pedal gently until you see brake fluid sweeping between the union and pipe.
Tighten these then go to the next pair of unions and do the same, then repeat for the front and rear circuits.
#6 Paul542
Paul542
    Just On Tickover
  • 6 posts
Posted 16 May 2020 - 07:00 PM
Thanks. I'll give this a go in the morning. Been at it since 8am this morning. Had enough today.
I'll report back
#7 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 16 May 2020 - 07:16 PM
First thing you want to do, before you begin bleeding is to check that the fluid level hasn't moved from where you left it... if its moved look under the pedal assembly at the bulkhead for fluid Marks.
#8 Paul542
Paul542
    Just On Tickover
  • 6 posts
Posted 17 May 2020 - 10:12 AM
I think I've just discovered the problem.
Left the car overnight found a fairly large puddle of brake fluid on the rubber mat in the drivers footwell.
I'm guessing this means the master cylinder is the culprit.
#9 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 17 May 2020 - 01:31 PM
Yes that's the issue! You need to replace it, I wouldnt even think about refurbishment
