Calling Mpi Pros---
Best Answer Tones61 , 19 May 2020 - 08:37 AM
Traced out a inlet manifold air leak,the locating rings were too wide for new head,
Ground them down, Go to the full post
10 replies to this topic
#1 Tones61
Tones61
  • 441 posts
Posted 17 May 2020 - 02:06 PM
Hi guys,I have just fitted a gas flowed head and med 1.5 roller rockers,to my 2000 mpi,
Already has an lcb,decat, (with lambda fitted) rc40 system,
Upon running up to temp ,looks like centre lcb branch is a dull red hot colour,
I have since blocked off breathe tubes into throttle body which helped a little,
Do I need a updated fuel pressure reg as per the performance kit for the cooper mpi?
Thanks for any info/input
Edited by Tones61, 17 May 2020 - 02:08 PM.
#2 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 17 May 2020 - 04:05 PM
Sounds like it’s overfueling
How was it behaving before the mods?
#3 Tones61
Tones61
  • 441 posts
Posted 17 May 2020 - 04:45 PM
Hi,yes was running fine on lcb and exhaust,
Only since head swap
#4 tmsmini
tmsmini
  • 760 posts
  • Local Club: MOASF
Posted 17 May 2020 - 05:40 PM
I don't believe you need an uprated fuel pressure regulator as I ran something similar on an MPi engine with out an issue.
Does anyone close to you have a code reader to see if anything is revealed by sensor readings?
Terry
#5 Steve220
Steve220
  • 5,143 posts
  • Local Club: BMC
Posted 17 May 2020 - 05:56 PM
Dull red colour is you're either your timing is running too advanced, and/or you're running lean. What are your AFRs? What cam have you got fitted?
Edited by Steve220, 17 May 2020 - 09:16 PM.
#6 Tones61
Tones61
  • 441 posts
Posted 17 May 2020 - 08:48 PM
Dull red colour is you're either timing running too advanced, and/or you're running lean. What are your AFRs? What cam have you got fitted?
#7 Tones61
Tones61
  • 441 posts
Posted 17 May 2020 - 08:49 PM
Hi guys, standard cam, and not got a code reader, may buy one to see, thanks ?✌️
#8 Wazzah
Wazzah
  • 142 posts
Posted 17 May 2020 - 09:12 PM
Sounds lean. Did you fit the larger MPI 52mm throttle body by chance?
#9 Tones61
Tones61
  • 441 posts
Posted 18 May 2020 - 07:34 AM
#10 Tones61
Tones61
  • 441 posts
Posted 18 May 2020 - 07:35 AM
Hi,no it's all standard except the flowed head,lcb,rc40 :-)
#11 Tones61
Tones61
  • 441 posts
Posted 19 May 2020 - 08:37 AM   Best Answer
Ground them down,
