Ok The Old She Won't Start But With A Twist
Best Answer cal844 , 18 May 2020 - 09:21 AM
I spy random added wiring, what are these for? Go to the full post
20 replies to this topic
#16 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 24 May 2020 - 02:34 PM
Have you confirmed the spark plugs are sparking? If not,
Remove a plug from the head
Refit the ht lead to the plug
Rest the plug on the head so it will sit without you needing to hold it.
Crank the engine while looking at the plug, you should see a consistent spark.
do this for all four plugs then clean and refit the plugs.
#17 postve
postve
  • 588 posts
Posted 06 June 2020 - 03:35 PM
Hey Cal
Turns out was power from the coil was dropping significantly - rewired as part of new harness and she is all good
#18 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 06 June 2020 - 08:36 PM
Hey Cal
Perfect, glad to hear the issue Is resolved, sounds like the issue may have been a partially broken wire.
#19 postve
postve
  • 588 posts
Posted 07 June 2020 - 01:08 PM
<blockquote class='ipsBlockquote'data-author="cal844" data-cid="3652321" data-time="1591475771"><p><p>I suspect as much or more so the incorrect gauge of wire is another possibility - now, we are on the lookout for a front end wiring harness
#20 sonscar
sonscar
  • 3,255 posts
Posted 07 June 2020 - 01:14 PM
This is a problem with multimeter's for testing,if only one strand of wire is still connected it may still read 12volts.Testing with the load applied should show this.Steve..
#21 postve
postve
  • 588 posts
Posted 07 June 2020 - 01:20 PM
Interesting Steve as I tested it multiple times so never questioned the reading until an older English mini mechanic mentioned likely the source of my troubles
