Rust And Hole In Rear Companion Compartment
2 replies to this topic
#1 Andygwk
Andygwk
    Starting My Mini Up
  • 1 posts
Posted 18 May 2020 - 09:02 PM
Hi All
There's some quite bad rust and a hole in the back right companion compartment. It looks to me to be threw the inside sill? is that correct? would this be an MOT Fail.
What sort course of action would you recommend to deal with this?
Andy
Edited by Andygwk, 18 May 2020 - 10:09 PM.
#2 mab01uk
mab01uk
  • 13,082 posts
Posted 18 May 2020 - 10:11 PM
Quite common on Minis and part of the inner sill and rear subframe mounting area, so should be an MOT fail, although I don't think MOT testers are allowed to remove interior trim like the liner so may not be seen. However for your own peace of mind any serious structural corrosion like that should be repaired asap.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 19 May 2020 - 08:13 PM
You have multiple issues there unfortunately. The inner sill being one, probably the heelboard end being another one, the bottom section of the quarter panel and that will have affected the outer sill.
All repairable but not a five minute job.
But as mab01uk has stated unless that can be seen from the outside of the car at all then its unlikely for the MOT tester will see it from inside of the companion bin if the liner is installed.
