Mini Mayfair Headlamp Confusion
4 replies to this topic
#1 MiniMae1994
MiniMae1994
    Starting My Mini Up
  • 1 posts
Posted 18 May 2020 - 09:53 PM
Hi all,
My Mini Mayfair 1275 1994 failed her MOT today and a number of the defects were electrical including headlights, horn and fog light. I've changed all of the fuses in the 4 fuse fusebox and checked/replaced with new bulbs and am still having issues.
Horn not working
Position Lamp not working - nearside rear
Rear fog lamp not working
Registration plate lamp not working
On full beam I have no front headlights working at all
On main beam I have both headlights working - top bulb only
On dipped beam I have just the nearside lower bulb working
I am wondering if there are any other fuses I should be looking to change and where they might be located. I have very little knowledge of fixing car electrics but am keen to learn - just feeling quite baffled at the moment, so any advice or tips would be much appreciated.
Indicators, radio, heater, wipers, rear windscreen heater all work normally.
Many thanks in advance!
#2 GraemeC
GraemeC
  • 7,475 posts
Posted 19 May 2020 - 02:09 AM
Don’t understand this bit - Full beam and main beam are the same thing ie headlights on (switch in second position) and stalk pushed forwards (so the blue indicator light in the dash is lit up).
Do you mean full beam, dipped beam and sidelights?
Dipped beam is headlights on (switch in second position) and stalk in rear position (not pulled right back for ‘flash”)
Sidelights is switch in first position.
#3 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 19 May 2020 - 09:21 AM
Check behind the speedo binnacle for 4 inline fuses which are on blue/red and blue/white wires for the lights.
I've had two of these melt and cause issues.
#4 mini-mad-mark
mini-mad-mark
  • 925 posts
  • Local Club: northants wot no brakes
Posted 19 May 2020 - 09:44 PM
Don't know if they are the same on a 94 mini but on most minis I had (up to 92 MY) there are connectors under the slam panel that are often culprits for duff headlights/sidelights
Hard to explain fixes in writing - pictures help (video would be great) Pity I hardly ever get to the computer until its dark and too late to take pictures to explain.
#5 mini-mad-mark
mini-mad-mark
  • 925 posts
Posted 19 May 2020 - 09:45 PM
Joining a club is handy as there is likely to be someone to help; obviously a bit futile at the moment though
