Wiring Diagram For '93 Rio (Last Of Carb Models) ?
Best Answer cal844 , 20 May 2020 - 09:42 AM
I have the actual manual as a hard copy and Nial is right there is no mention of the carb model. The wiring diagrams just pertain to the SPI.
On my 94 carb model the wire that Nial says is yellow and white is just white although looks more like a cream colour.
It's _definitely_ yellow and white, it doesn't show up brilliantly in the photo but there's a defiinite yellow stripe.
It looks like they were just making it up as they went along!
That connector is non standard. The two dizzy wires go straight from the coil to the module on the side with no additional connectors. Go to the full post
17 replies to this topic
#16 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 20 May 2020 - 04:15 PM
Looks like someone has perhaps added a non standard colour wire.
As CAL844 said there is no inline connector at that point.
On mine the 2 wires go straight into the electronic module.
I think the lead should look something like this:
Top man, that is indeed the factory loom, there was also a 3 pin version too iirc.
I couldn't find the loom to link to ? must be the heat lol
#17 Nial
Nial
  • 75 posts
Posted 10 June 2020 - 02:49 PM
Thanks guys, the bottom of the distributor's fairly grubby, I didn't realise there was a connector into it!  >:-0
Correct wire ordered. :-)
[Edit] Would anoyone know what the correct condenser for this distributor / coil combination is?  [/Edit]
Edited by Nial, 10 June 2020 - 02:54 PM.
#18 GraemeC
GraemeC
  • 7,314 posts
Posted 10 June 2020 - 03:08 PM
No condenser on an electronic ignition setup - they're just for points
Edited by GraemeC, 10 June 2020 - 03:08 PM.
