Wheels
4 replies to this topic
#1 paccars
paccars
  • 0 posts
Posted 19 May 2020 - 12:07 PM
Hi I have a 1994 mini cooper with standard arches want to change the wheel to 12x 5.5 do I have to loose the rear spacer
Thanks paccars
#2 kit352
kit352
  • 256 posts
Posted 19 May 2020 - 03:53 PM
How thick is your spacer? How much offset is on your new rims?
#3 Spider
  • 15,865 posts
Posted 19 May 2020 - 06:06 PM
I've moved this topic over here as you'll likely receive a better response.
#4 Bobbins
Bobbins
  • 1,526 posts
Posted 23 May 2020 - 07:25 PM
Assume you're referring to the built in spacer in the rear brake drum? It really depends upon the offset of the wheels you intend to fit, i.e. ET?
Why specifically 5.5"?
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 23 May 2020 - 08:18 PM
5.5 inch will be fine with spacer drums,
I have a 1993 car with 6x12 revolution offset wheels and they're perfect with the standard arches.
