Which Length Protech Dampers?
4 replies to this topic
#1 Cooper Mac
Cooper Mac
  • Just Joined
  • 222 posts
Posted 20 May 2020 - 03:37 PM
After searching the forum for peoples recommendations on what adjustable dampers to fit, I've decided to get some Protech ones. (Thanks to all of you for your reviews!)
My question is which length to get?
I'll be running:
Red Dots
Adjustable trumpets
12" Wheels
Standard damper mountings
The adjustable trumpets are just to get the stance correct and gaps between the tyre and the arches. If I go for "Standard" length dampers, will this prevent me dropping the height of the car?
Cheers!
Nic
#2 GraemeC
GraemeC
  • 7,472 posts
Posted 20 May 2020 - 03:54 PM
It won't prevent you dropping it, but it may mean that the suspension dislocates on full droop (ie jacked up or if the wheel leaves the road for any reason) and/or you may bottom the shocks out on full compression.
Both of these are most likely at the rear.
If you are likely to be more than 1/2" lower than standard, then I would fit lowered height shocks.
#3 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 20 May 2020 - 04:28 PM
I have a set of standard length protech dampers for sale if interested, essentially brand new
#4 nicklouse
  • 19,057 posts
Posted 20 May 2020 - 04:33 PM
Have a read https://www.calverst...damper-lengths/
#5 Midas Mk1
Midas Mk1
  • 5,852 posts
  • Local Club: S.U.N.M.C
Posted 20 May 2020 - 07:45 PM
With standard protecs on both my mini and Midas it was sat on the shocks, ie no travel, lowered items sorted this.
