Rear Floor Length Countryman
9 replies to this topic
#1 1968cooper
1968cooper
  • 95 posts
Posted 20 May 2020 - 08:57 PM
Would someone kindly measure from the rear of the seat crossmember to the front of heelboard, long wheelbase Mini please?
It’s a long story but my car has been welded across the floor behind the seat crossmember and measuring the wheebase it appears to be 7-8mm too short.
#2 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 20 May 2020 - 09:58 PM
If I remember tomorrow I shall measure my clubman Estate
#3 MikeJE
MikeJE
  • 143 posts
  • Local Club: LSMO
Posted 25 May 2020 - 02:39 PM
Happy to measure my countryman, 1968c, but not sure what is meant by the front of the heelboard (sorry, showing my ignorance!). If you let me know I will wield the tape measure pronto....
Best wishes
Mike
#4 KTS
KTS
  • 2,490 posts
Posted 25 May 2020 - 08:06 PM
rear of crossmember to the heelboard is 35.75" on my pickup
#5 Homersimpson
Homersimpson
  • 851 posts
Posted 25 May 2020 - 09:41 PM
The crossmember position isn't that fixed/critical and could be a bit more one way or the other, you really need to measure from the suspension mountings.
#6 1968cooper
1968cooper
  • 95 posts
Posted 29 May 2020 - 05:57 PM
thank you, that is interesting as your pick is within .12" as my measurements are 35.62" at tunnel and 35.87" at side bin
#7 1968cooper
1968cooper
  • 95 posts
Posted 29 May 2020 - 06:03 PM
Thank you. I appreciate that your suggested method would be the best but I do not have the subframes on the car at the moment as the mounting plates have disintegrated
#8 1968cooper
1968cooper
  • 95 posts
Posted 29 May 2020 - 06:10 PM
Best wishes
Mike
Hi Mike, I am probably showing my ignorance and not using the correct term, I believe it is the panel at the very rear of the floor.
#9 KTS
KTS
  • 2,490 posts
Posted 29 May 2020 - 07:04 PM
Best wishes
Mike
yep - that's right; Heel board is the vertical panel at the rear of the floor pan (the one the subframe bolts to), conversely the toeboard is the panel that goes between  the front edge of the floor pan to the bulkhead
either of you know what or where the flitch panel is ?  i'm still struggling with that one..
#10 1968cooper
1968cooper
  • 95 posts
Posted 29 May 2020 - 09:09 PM
Best wishes
Mike
I always thought the flitch panel was the inner front wing.
