Right Hand Engine Mount
Posted 21 May 2020 - 06:36 AM
Posted 21 May 2020 - 06:42 AM
What year is the car...
Posted 21 May 2020 - 07:06 AM
You've got 3 awkward engine mount bolts to to remove with the wok in place or 2 awkward wok bolts then replace the mount with the wok off.
Posted 21 May 2020 - 09:25 AM
Posted 21 May 2020 - 11:57 AM
I've done that one both ways and I find it easier though a little longer to do if the cover is removed.
Posted 21 May 2020 - 12:23 PM
You need to jack that side of the engine up so I
1.remove the Rad
2. loosen but dont take the nuts off the left hand mount
3. undo the top stabiliser arm
4 undo the right hand mounts from the sub frame.
5. Jack the right hand side of the engine up as high as you can without fouling th eexhaust on the body and remove the wok
Posted 21 May 2020 - 12:26 PM
and while the wok is off check the clutch release bearing and replace if necessary and lube the clutch arm bits while its all off too
Posted 21 May 2020 - 02:42 PM
Posted 21 May 2020 - 06:31 PM
Posted 22 May 2020 - 07:01 AM
Posted 22 May 2020 - 07:10 AM
1. Recommendations for lube for clutch plunger linkage? Dry graphite?
2. The old clutch plunger has a recess inside the hole on the thrust side to accept the ball of the clutch lever, probably from wearing against the ball end of the lever, hence the question regarding lubrication.
3. The old clutch release bearing was weeping lubricant, am considering using the GRB201EVO bearing from MiniSpares. Opinions?
Edited by croc7, 22 May 2020 - 09:19 PM.
