Understanding Gear Ratios
9 replies to this topic
#1 charliefarlie37
charliefarlie37
  • 149 posts
Posted 21 May 2020 - 10:51 AM
Hi, I'm running a 998 in my pup on 10" rims, I've a choice of 2 gearboxes, one is 3.65:1 ratio and the other is 3.44:1 ratio, which will give the best top speed?
#2 GraemeC
GraemeC
  • 7,476 posts
Posted 21 May 2020 - 11:00 AM
3.44 will give a higher speed in each gear, but slower acceleration.
(That is, assuming everything else is the same)
Edited by GraemeC, 21 May 2020 - 11:00 AM.
#3 timmy850
timmy850
  • 3,615 posts
  • Local Club: MITG
3.44 will give more speed
#4 charliefarlie37
charliefarlie37
  • 149 posts
Posted 21 May 2020 - 11:16 AM
Thank you for that, looks like I'm swapping gearboxes this weekend ?
#5 timmy850
timmy850
  • 3,615 posts
  • Local Club: MITG
Posted 21 May 2020 - 11:21 AM
You can also just swap the diff and pinion gear rather than the whole gearbox
#6 Spider
  • 15,878 posts
Posted 21 May 2020 - 11:45 AM
Research your speedo drive too !
You may need to change it
#7 sonscar
sonscar
  • 3,257 posts
Posted 21 May 2020 - 11:50 AM
Plus one for the speedo drive.It is character building when the power unit is back in the car.I did this.Steve..
#8 charliefarlie37
charliefarlie37
  • 149 posts
Posted 21 May 2020 - 11:57 AM
Bit of a longer story, original engine and gearbox according to guess works is coming up as the 3.65:1 ratio and an a+metro engine, the 3.44:1 gearbox is attached to an a engine which is alot cleaner etc than the present engine fitted. Whilst I have 5 days off I'm thinking of biting the bullet and changing it.
Just need to work out the best way of going about it, will need to be able to move the mini around as I wont be able to commit a full day at it, so will need to be able to push it in and out of my garage.
#9 sonscar
sonscar
  • 3,257 posts
Posted 21 May 2020 - 12:00 PM
Pretty much what I did,to do it in one day is beyond me but I am a bit of a duffer.Start early!.Steve..
#10 charliefarlie37
charliefarlie37
  • 149 posts
Posted 21 May 2020 - 12:06 PM
Haha I wish I could lend a whole day to it, unfortunately my partner and son wont like that lol, plus I'm going to have to do it on a gravel driveway so it will be challenging with the engine crane. All good fun lol
