35B58E1C-2B48-40CF-98DF-3AD43F8B3F63.jpeg 41.67K 4 downloads
Thanks ..
Edited by johnv, 22 May 2020 - 12:46 PM.
Posted 22 May 2020 - 12:44 PM
Thanks ..
Posted 22 May 2020 - 01:04 PM
You should have a squared "U" shape bracket on top of the mount - with a one arm holed at the top and the opposite side with a captive but in it....(takes a 4" or so bolt to mount the rad)
Quick edit er ! - Looks like you have an early engine in which case right bracket - wrong way round!!...assuming using the ealry 2 piece rad cowling...
Edited by wile e coyote, 22 May 2020 - 01:09 PM.
Posted 22 May 2020 - 01:06 PM
Posted 22 May 2020 - 01:22 PM
Posted 22 May 2020 - 01:30 PM
You need the cooper S bracket that is shaped to clear the damper, you also need the matching rad cowling. I bought both from minispares, they needed quite a bit of work to make them fit.
This? http://www.minispare...|Back to search
Posted 22 May 2020 - 01:36 PM
Posted 22 May 2020 - 01:58 PM
It’s the old style 2 piece cowling .. I think it’s the minispares one I need, the one I have must be for the narrower pully
Posted 22 May 2020 - 02:27 PM
Posted 22 May 2020 - 02:48 PM
