Dipsticks Tubes - Pre A+
30 replies to this topic
#1 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 23 May 2020 - 09:55 AM
What is the correct dipstick and tube to use for a pre A+ 1275 12G1279 block? I’ve tried quite a few combinations and can’t get one to fit
#2 blacktulip
blacktulip
  • 6,231 posts
Posted 23 May 2020 - 10:16 AM
That's the correct one. Doesn't the dipstick fit? Have you got the tapered plug type dipstick?
#3 nicklouse
  • 19,062 posts
Posted 23 May 2020 - 10:39 AM
The dipsticks are all the same other than the auto and the very early 850.
you must have picked up a non Mini one.
#4 Spider
  • 15,861 posts
Posted 23 May 2020 - 10:49 AM
They fitted the Plastic ones from earlier on, prior to that, they were Steel, but either of these fit.
I gotta say, I haven't found the new Plastic ones too good.
#5 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 23 May 2020 - 11:06 AM
Attached File  4BF976E3-8F33-430E-A55E-4FB459891641.jpeg   47.85K   9 downloads
#6 nicklouse
  • 19,062 posts
Posted 23 May 2020 - 02:47 PM
what do you mean by
#7 nicklouse
  • 19,062 posts
Posted 23 May 2020 - 02:52 PM
looks right but aint the beast picture,
here are some for you to compare with.
#8 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 23 May 2020 - 02:59 PM
Thanks Nick I’ll go and re-check with this info
#9 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 24 May 2020 - 11:09 AM
Is this the same? It seems to be about 1cm too long
#10 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 24 May 2020 - 11:11 AM
Another ..
#11 GraemeC
GraemeC
  • 7,473 posts
Posted 24 May 2020 - 12:03 PM
Overall length doesn’t matter that much, it’s the length to the markings that’s important
#12 nicklouse
  • 19,062 posts
Posted 24 May 2020 - 12:04 PM
what do you mean by
I will ask again.
what is the actual problem.
#13 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 24 May 2020 - 12:30 PM
It’s too long! When in the tube it doesn’t go all the way to the collar, it jams.
#14 nicklouse
  • 19,062 posts
Posted 24 May 2020 - 01:23 PM
so what is the length of the sticky out bit?
#15 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 24 May 2020 - 01:42 PM
33mm
