ok next what is the measurement of the MAX and MIN as per my picture?
Dipsticks Tubes - Pre A+
#16
Posted 24 May 2020 - 02:12 PM
#17
Posted 24 May 2020 - 02:45 PM
Does my last pic not show that? Sorry, not with you
#18
Posted 24 May 2020 - 03:04 PM
nope none of your pictures show the max min marks. you only show the smooth back side.#
here (as posted earlier bigger? you can see the length from the fixed metal stop on the dipstick
and then the detail of the measurement
either look at the earlier post of click for bigger
#19
Posted 24 May 2020 - 03:08 PM
#20
Posted 24 May 2020 - 03:15 PM
These?
Posted 24 May 2020 - 03:16 PM
It’s chopped the first one off but the zero was where yours was
#22
Posted 24 May 2020 - 03:32 PM
i would just chop the bottom of the stick. as everything seems to measure up other that the length.
but before that just check there is nothing in the box stopping it.
#23
Posted 24 May 2020 - 03:34 PM
Ok .. it’s only about 5mm out I think..thanks for you time!
#24
Posted 24 May 2020 - 03:53 PM
Nothing wrong with the dip stick, it is the tube which is wrong - the upper portion looks too short.
#25
Posted 24 May 2020 - 03:58 PM
New this week from Somerford.. Not that that means much, they said it was the correct one, maybe they got then made too small
#26
Posted 24 May 2020 - 04:10 PM
New this week from Somerford.. Not that that means much, they said it was the correct one, maybe they got then made too smallNothing wrong with the dip stick, it is the tube which is wrong - the upper portion looks too short.
And you measured it and said it was 33mm which if anything is a tad long.
I have just been sticking thing into the dip stick hole on the empty A+ block and remote gearbox case I have dummying up in the car. And there is something that can get in the way. And you can find a 5 mm difference in depth.
#27
Posted 24 May 2020 - 04:48 PM
#29
Posted 24 May 2020 - 07:15 PM
Edited by johnv, 24 May 2020 - 07:15 PM.
#30
Posted 24 May 2020 - 07:23 PM
You see the bump? That is just about where the dip stick goes. No I have no idea if that is directly below the dip stick or should be to one side. I don’t know how straight the plastic tubes fit.
so as your stick is a few mm too long it could be touching the bump or instead of being next to the bump it is above it.
like I said earlier as the tube is the right length. The max min marks are about the same just trim the stick.
