Assembly Of The Gears
4 replies to this topic
#1 neet street
neet street
  • 42 posts
Posted 23 May 2020 - 10:06 AM
Hi, I am putting the gear box together on my 1984 mini mayfair, and the 1st gear seems to have alot of `float` and nothing to hold it in place to stop it moving to the center web? is there something I am missing?
thank you for any help you can offer
John
#2 Spider
  • 15,839 posts
Posted 23 May 2020 - 10:52 AM
The Sleeve that First Gear Needle Roller (and first gear) fit on to is locked when fitted up between the splines that the 1/2 Synchro Hub locate on to the the 3rd Motion Shaft Bearing. It's pulled town tight when the Pinion is fitted and then the Nut is tightened up.
#3 neet street
neet street
  • 42 posts
Posted 23 May 2020 - 11:23 AM
Thank you, this is what is have (see pic) What are your thoughts please?
Attached File  mini gears 1.jpg   31.91K   7 downloads
Attached File  Mini gears 2.jpg   31.64K   7 downloads
#4 Spider
  • 15,839 posts
Posted 23 May 2020 - 11:39 AM
The 3rd Motion Shaft needs to be slide over further, much further, towards the center web.
The 3rd Motion Shaft Bearing will position it.
#5 neet street
neet street
  • 42 posts
Posted 23 May 2020 - 12:47 PM
perfect thank you, also noted the main bearing was not in far enough :-)
all good now, and thank you for your help
