Ball Joint - No Shims - Still Loose
6 replies to this topic
#1 chilli1
chilli1
  • 13 posts
Posted 23 May 2020 - 11:21 AM
Hi All,
As the title says really.
I've fitted the bottom ball joint and have reached the point where I only have the lock washer and no shims but there's still play in the pin.  Hard to measure but I'd say at least 5 thou.
I've tried the old ball joint and a fresh one and it's the same with both.
Any suggestions?  Or is it new swivel hub time?
#2 andyapanel
andyapanel
  • 651 posts
Posted 23 May 2020 - 11:39 AM
Have you refitted the spring?
#3 chilli1
chilli1
  • 13 posts
Posted 23 May 2020 - 11:50 AM
No, I'm setting it up before adding the spring.
#4 Dusky
Dusky
  • 5,322 posts
Posted 23 May 2020 - 02:12 PM
Is it a new balljoint?
Hardened washer under the balljoint cup works. But I'm guessing it's a low quality joint.
#5 greenwheels
greenwheels
  • 691 posts
  • Local Club: Mini Fixers
Posted 23 May 2020 - 02:19 PM
Check there isn't an old shim still stuck on the hub.
#6 chilli1
chilli1
  • 13 posts
Posted 23 May 2020 - 02:36 PM
It's not a new joint. I disassembled it to clean up the hub and am now at the point of re-assembly.
I've tried a new joint as well though, same issue.
I'll double check for shims
#7 Spider
  • 15,873 posts
Posted 23 May 2020 - 06:14 PM
I recall having one like this. It all looked OK, I didn't have time to measure parts to see where the error was, I just machined a little off the Cup of the Ball Joint.
