Torque Setting For The Lower Steady Bar Bracket
Best Answer GraemeC , 23 May 2020 - 06:06 PM
18 lbft / 25Nm
Listed as flywheel housing nuts & bolts in Haynes
Go to the full post
10 replies to this topic
#1 miniharryg
miniharryg
    Starting My Mini Up
  • 3 posts
Posted 23 May 2020 - 11:40 AM
Hi
First post - so first introducing myself - I am a 14 year old doing up a 1990 998cc Flame Red mini with the help (? ;-)) of my Dad.
All going well to date, with engine out of the car, cleaned up, painted etc and now going back in.
We cannot find the recommended torque settings (in the Haynes, or on here) for the bolts that go into the gearbox for the bracket (KKU10080) that the lower steady engine steady bar uses.
I attach a photo of the relevant bolts (not from our car, found on elsewhere on this site whilst trying to find the answer.
Attached File  post-50225-0-55202800-1371336276.jpg   50.76K   1 downloads
Please can somebody help, and perhaps also advise where we should have been able to find it so we know for next time!
Harry
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 23 May 2020 - 11:52 AM
If you do not find torque values on a manual then as long as you know the size of the bolt / fastener you are using then you can use a guide like this
https://www.norbar.c...eValueGuide.pdf
#3 nicklouse
  • 19,067 posts
Posted 23 May 2020 - 12:16 PM
8nm or 6lbf
#4 nicklouse
  • 19,067 posts
Posted 23 May 2020 - 12:17 PM
Ps Haynes does have it but it calls them studs.
further looking for the same size and thread form gives 22-25Nm as being acceptable.
Edited by nicklouse, 23 May 2020 - 01:18 PM.
#5 miniharryg
miniharryg
    Starting My Mini Up
  • 3 posts
Posted 23 May 2020 - 04:21 PM
Thanks!
#6 nicklouse
  • 19,067 posts
Posted 23 May 2020 - 04:26 PM
Thanks!
read my second reply. as it could be a higher value.
#7 GraemeC
GraemeC
  • 7,476 posts
Posted 23 May 2020 - 06:06 PM   Best Answer
18 lbft / 25Nm
#8 Spider
  • 15,881 posts
Posted 23 May 2020 - 06:10 PM
Cars prior to about 84 - 85 had Studs and Nuts here.
#9 nicklouse
  • 19,067 posts
Posted 23 May 2020 - 06:27 PM
it just looks like they did not bother distinguishing between the thread form or the material it went into later on.
#10 Spider
  • 15,881 posts
Posted 23 May 2020 - 06:32 PM
No, they didn't.
When reading these later manuals, in many areas, they totally ignore earlier cars, in fact, if I recall the titles, they do actually have a year range on them.
#11 miniharryg
miniharryg
    Starting My Mini Up
  • 3 posts
Posted 25 May 2020 - 02:36 PM
Thanks All for following up - we have used 25 as recommended
