To be slightly fair to the guy, if its a big operation, and engine is only as good as the actual guy who did the build. If its a one man operation though then there are no excuses whatsoever.
Would it be worth letting him "rebuild" it, again then checking it when you get it back.?
The company is Retro Minis - They have a website under that name, looks very professional, spoke with the guy and he seemed very genuine and knowledgeable. He has been working with minis since 1979. Agreed a list of work to be done on my head and block only. Took the block and head to him to be checked over and advise true cost. Received cost and agreed payment terms. I was not in a rush as this is a slow project based on time and money. He agreed to send pictures to keep me updated on the build.
This is the list of issues -
Cam should have been 264T as displayed on his site - Mini spares evolution 001 fitted - acceptable but cheaper option not discussed
Cam bearings should have been replaced - Not done
Pushrods replaced, checked for straightness - when i removed these 2 were excessively bent. 4mm curve
Cam followers he insisted should be ISKY - when removed and inspected they are possibly original or maybe mini spares £2.00 ones
Crank polish - looks clean but always did so i dont know
Main bearings - not done
New original metro turbo pistons - These were advised as original. Hard to get, limited stock, - Fitted are MEGA pistons form mini spares
New high grade studs and nuts for head - studs are new but quality unknown - original nuts fitted
CR should have been checked - He forgot
Rocker rebuild with new studs - studs so bent rocker did not want to come off. Grip marks on the side when finally remove
New IWIS timing chain insisted by him - removed cover to find Rolon half rusted chain.
I must admit im worried about piston rings, bore size, double spring set, valve seats because i now need to inspect all.
He has agreed to do the work but is 200 miles away from me. Plus with this list above i would not want to leave the engine there again in fear it disappears. I have spoken with him but must admit I don't hold much hope of ever receiving the parts discussed.
Seems to me that obvious parts were replaced, those difficult to tell parts were not. He could not explain on the phone what had happened. I think we all know why.
