Window/door Issue ?
Posted 25 May 2020 - 12:22 PM
Thank you Lee
Posted 25 May 2020 - 01:20 PM
You could try packing the 'low side' of the glass support rail with an alloy firring piece.
Posted 25 May 2020 - 01:36 PM
Do mean remove the metal runner from the glass and put a Packer under it then re fit ? Sounds like a good idea ?
Posted 25 May 2020 - 01:44 PM
Yes, a piece of alloy cut in a long thin triangular shape.
Posted 25 May 2020 - 01:55 PM
Do mean remove the metal runner from the glass and put a Packer under it then re fit ? Sounds like a good idea ?You could try packing the 'low side' of the glass support rail with an alloy firring piece.
R right I see, maybe just packing one side of the runner may be easer and would a do the same I reckon, may be worth a try thank you mate
Posted 29 May 2020 - 07:39 PM
Edited by leepol83, 29 May 2020 - 07:40 PM.
Posted 29 May 2020 - 08:47 PM
Posted 29 May 2020 - 10:20 PM
Posted 30 May 2020 - 06:37 AM
Something I hadn’t thought of if I’m jones but a good shout i think I’ll have a look thanks for that ??I've electric windows on mine and can't remember what the winders look like or if what I'm suggesting is feasible but could you try moving the the low side arm on the winder round a tooth on the cog.
If anyone has advice how to do this it would be appreciated
Edited by leepol83, 30 May 2020 - 06:40 AM.
Posted 30 May 2020 - 06:55 AM
Edited by leepol83, 30 May 2020 - 06:56 AM.
Posted 30 May 2020 - 12:47 PM
It’s more likely that the steel channel on the bottom of the glass has shifted and needs levelling.
Posted 30 May 2020 - 03:37 PM
Hi the window does go up nice and strait it’s the fact that I’ve cut about 5mm out of the frame that’s the issue, when. I have the window slightly open it doesn’t loot strait cus if the extra metal I've welded in, basically I’m trying to get the window to go up uneaven so it looks betterAdding or removing metal frame the window should have no effect on the angle at which the windows goes up and down.
Edited by leepol83, 30 May 2020 - 03:37 PM.
Posted 30 May 2020 - 03:44 PM
If you start messing with the angle of the glass you’re likely to have issues with the running up and down smoothly as it will effectively become winder the more you rotate it to match the top of the door frame.
Get some pictures up so get a proper idea of what going on.
Posted 30 May 2020 - 04:34 PM
Ye that’s my issue mate as it does run up and down lovely and seals fine at the top at the moment at the moment it’s just when I slightly open it the glass doesn’t look level, my original problem was the door in the actual opening itself which is completely from the factory and the original door, I sorted this by cutting the frame only one side thow which is my issue ?♂️So the top of of your window frame isn’t parallel with the top of the door skin?
