I'm new to the forum and I would be truly grateful if some could point me in the direction of what to do next...
I own an '96 SPI mini (blue star edition)
The problem:
When the engine is cold and I turn the key - the engine cranks with no signs of starting.
It will start if
a) I add easystart
b) I remove all the spark plugs , turn the engine for a second, put back the sparkplugs.
No problem driving around after starting and the car starts without a problem when warm.
There is spark, the engine gets fuel, the pump primes, the voltage is ok.
I have
1) Checked the vacuum lines
2) Cleaned basic ground contacts
2) Checked valve clearances
3) Changed to new spark plugs and capped correctly
4) Changed the crank shaft sensor
5) Changed the coil
Currently waiting for a new coolant temp sensor.
....Please help....
UPDATE:
Changed the CTS - starts like normal now.
Big Thanks for the help!
Edited by largo, 06 June 2020 - 04:52 PM.
