Right Indicator
Posted 27 May 2020 - 12:31 PM
Posted 27 May 2020 - 05:39 PM
First thing I would try is cleaning up any and all earthing points you can find, you would be surpised what problems they can cause.
Posted 27 May 2020 - 06:46 PM
Posted 27 May 2020 - 09:09 PM
Thank you.
Posted 27 May 2020 - 09:44 PM
Thank you. I’ll try the earth points. I assume the indicator housings are earthed through the fixing screws. Any hidden earth point apt be aware of?
Thank you.
Not with the clubman models, clean up the bullet terminals behind the front panel then the main earth point
Edited by cal844, 27 May 2020 - 09:46 PM.
Posted 27 May 2020 - 09:48 PM
i had the same type of problem when i did the van, it was the bullet connectors at the front. I was lucky to find it!
Posted 28 May 2020 - 12:24 PM
