Alternator Problems
Posted 29 May 2020 - 05:54 PM
Regards
Posted 29 May 2020 - 06:50 PM
Posted 30 May 2020 - 06:15 AM
Posted 30 May 2020 - 09:33 AM
Posted 31 May 2020 - 02:37 PM
I had a look around the engine bay where I took the grill off, but I can’t seem to see any wires not connected, I’ve checked all leads etc and nothing.
I’m going to go back out tomorrow and see if there’s anything else. Like u said it’s probably something simple. Well I hope it is ?
Posted 01 June 2020 - 06:37 AM
Any vacuum hoses disconnected or split?
When you say it won't run do you mean it won't start, or starts and then stops, or starts ok but just runs rough?
Posted 01 June 2020 - 09:04 AM
Posted 01 June 2020 - 09:05 AM
Posted 01 June 2020 - 09:35 AM
I had a similar thing on mine recently, thought it was the alternator plug wiring but turned out the battery cable had worked loose on the starter motor, the brass nut had started to undo.
Was running on and off according to if the connection was being made or not.
Posted 01 June 2020 - 09:52 AM
Posted 01 June 2020 - 01:24 PM
Check you haven't knocked the lead on No1 plug and damaged or displaced it.
Posted 01 June 2020 - 06:20 PM
Posted 02 June 2020 - 02:53 PM
Thanks again.
