Rubber Cone Replacement
Posted 30 May 2020 - 11:03 AM
Posted 30 May 2020 - 11:09 AM
it helps. i always used one.
Posted 30 May 2020 - 11:11 AM
I'd say yes.
You might get the old cones out without one, but getting the new ones in and seated with the knuckle joint seals in place is another matter.
If you're on a budget & have the time you might get by with some threaded rod.
Posted 30 May 2020 - 11:23 AM
I've just replaced the 48 year old cones on my car (I have hilo's)
No problem removing old cones without a compressor - rebound bumper removed and shock removed and the upper arm moved up and down without being under any spring tension.
Compressor needed to fit replacement cones even with hilo in shortest position.
Got the rears replaced just by winding hilo to shortest position.
Posted 30 May 2020 - 11:32 AM
I have done it without, but with standard rubber cones it does take careful use of pry bars to get the top arm up and the pin back through it.
If I remember rightly it is easier with red spot cones as they're a bit shorter.
If you value your fingers and/or aren't confident, then investing in (or borrowing) the tool is advised.
Posted 30 May 2020 - 11:41 AM
reds are longer.
Posted 30 May 2020 - 11:43 AM
Are they - I thought they were shorter and squarer, never compared them side by side though.
Posted 30 May 2020 - 11:45 AM
from Minispares
Hilos will be required to enable fitment as they are taller
Posted 30 May 2020 - 12:35 PM
That's slightly different - yes they are taller once the weight of the car is on them as they don't have the initial compression of the standard ones.
I'm sure if you put two new ones side by side on the bench the standard one is taller due to its very pointy shape.
Posted 30 May 2020 - 01:07 PM
I'm sure there are hundreds sitting in sheds that get used once every blue moon.
I'm in south bucks - you're more than welcome to use it.
Posted 30 May 2020 - 01:49 PM
I would say you definitely do, I have HiLos and having just fitted new cones, there is no way on earth I'd have fitted them without a compressor.
Not worth messing about for the sake of what, 30 quid?
Posted 31 May 2020 - 03:31 PM
can you put out a request to loan a spring compressor in your area.?
Thanks for the offer...but I'm from Trinidad.
