Removing Fan Belt
Posted 31 May 2020 - 06:38 PM
Mk1 with 998cc engine. I’m in the process of cleaning the cooling system after some time in storage. Dynamo and water pump out, but the fan belt can’t get past the crankshaft pulley. There must only be a couple of mm space between that and the engine mount bracket. Any suggestions? I’ve never had to remove the engine to replace a fan belt before!
E3CBAE53-F181-4560-84B5-386FEB9A3E56.jpeg 94.58K 6 downloads
Posted 31 May 2020 - 07:18 PM
Hmmm maybe the wrong damper pulley
Posted 31 May 2020 - 07:36 PM
just loosen engine mount / stabilisers and jack the engine up asif you were changing the clutch with the engine in , except the fan side of the engine
Posted 01 June 2020 - 12:00 PM
Thanks - although by loosening the LH engine mount I think the bracket will still be in the same place?
Looking into this some more - I have a 998 Cooper engine in a Mk1 that didn't originally have it (I still have the orginal in various boxes). I assume the engine mount bracket is original - which differs from the Cooper one that I believe is similar to the later brackets. Presumably this allows the required sapce around the larger pulley
Wonder if anyone else has done this swap and whether a newer-style bracket is an alternative to attach to the engine?
Posted 01 June 2020 - 12:17 PM
Posted 01 June 2020 - 12:28 PM
Isn't it possible to loosen the bracket to provide enough clearance?
It looks, in the photograph, like it's bolted on.
Edited by Quinlan minor, 01 June 2020 - 12:29 PM.
Posted 01 June 2020 - 01:10 PM
It looks like you have the crank pulley with the larger damper as fitted to the Cooper 'S'.
You need to remove the bracket by undoing the mounting bolts through the sub-frame, then jacking the engine up a bit. Rompve the bracket and file it to give just sufficient clearance for a fan belt to be fitted or removed. You won't need to take much of, maybe 1/8" just on the bottom of the bracket.
