Spi Charging Problem
16 replies to this topic
#16 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 26 June 2020 - 06:20 PM
Glad to know that you could fix the problem. However, if you used a regular piece of wire it will not provide any protection as the fusible link does. Shop, around and you might find a suitable replacement.
Hi again
Can I ask what gauge of fusible link wire you used? Or what amps rating?
David
This is what I used since it seemed to be about the same gauge as the original. Apparently, the general rule for the fusible link gauge is that it should be 4 gauges smaller than the wiring being protected. So, the length and gauge should be the same as the factory installation for the proper protection.
https://www.oreillya...niversal)&pos=2
I could not find anything in Minispares or Somerford and Amazon.co.uk had huge sizes and expensive.
Amazon US has one at a more reasonable price that you might be able to get if you can not get something locally:
 https://www.amazon.c...PVNV1NSG8W5Z0F1
#17 Wriggler
Wriggler
    Just On Tickover
  • 8 posts
Posted 29 June 2020 - 09:37 AM
Hi again
David
Excellent!
Thanks for that.  I'll see what I can find.
