The below mini isn't mine but is a perfect picture for what I need ?
3 replies to this topic
Posted 07 June 2020 - 11:03 PM
Hi all. I'm getting a rattle from my exhaust in the middle of the car and was wondering if there are any specific brackets I can install to stop it. I have the fitting at the red circled locations but want something in the middle blue circled section.
Posted 08 June 2020 - 05:21 AM
If that was your car I think you would have a bigger problem than a rattling exhaust
It’s not touching the handbrake anywhere is it
Edited by steeley, 08 June 2020 - 05:24 AM.
Posted 08 June 2020 - 09:34 AM
Try loosening all the clamps and wiggle it and see what it is hitting, in the case of the recent RC40 install on the Cooper the rear box was just slightly touching the subframe, and hence pushing it a few millimetres the opposite way cured it.
Posted 08 June 2020 - 09:47 AM
There has never been any exhaust fitting in the blue area. So if you are wanting one you will have to make something.
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
