Serviced The Car And Now She Wont Start
Best Answer evilpen14 , 12 June 2020 - 02:56 PM
Thank you for the help I identified the issue as a lose connection to the coil. Go to the full post
Posted 11 June 2020 - 06:06 PM
Posted 11 June 2020 - 06:16 PM
When you say cut out, do you mean instantly or spluttered and died?
Posted 11 June 2020 - 06:28 PM
B955D8B7-4F71-4A22-8071-30543F4F220D.jpeg 32.86K 1 downloads
going to need more information to be able to help. Right to check the basics, fuel and spark.
FS
Posted 11 June 2020 - 06:36 PM
The one relay on the bulkhead could have tripped out, these are the 2 black square box things on the bulkhead on the right as you look into the engine bay (Technical term - box things by the way)
If it started and moved a few feet, that's a start !
Posted 11 June 2020 - 06:43 PM
It drove and then sputtered and died and now wont start
Posted 11 June 2020 - 06:44 PM
Will it be obvious how to reset it when I open the boxes?
Posted 11 June 2020 - 08:17 PM
Have a look at the vacuum hoses in case you have knocked one off whislt under the bonnet.
Posted 11 June 2020 - 08:23 PM
This won’t cause it to cut out....
Posted 11 June 2020 - 08:25 PM
Evilpen14
More info please and I’m moving to fuel injection.
Posters please remember the rules of the technical section.
FS
Posted 11 June 2020 - 08:35 PM
Did you disconnect the battery? Did you drop/lose any tools while doing the servicing particularly in the starter area? Did anything break or accidentally came off during the servicing? Did you wash the engine? Did you ensure to reconnect back everything in the right places? Just to start.
Posted 11 June 2020 - 08:38 PM
FS
Can I like you post more than once?
Posted 11 June 2020 - 09:04 PM
To be honest I was thinking about running/starting issues I have come across in the past, not Mini ones in particular.
Thought it was worth the suggestion since there isn't a lot of info to go on.
Posted 11 June 2020 - 09:42 PM
It’s fine. We just want posters to post as much as possible about the problem so we can be much more specific about the help.
Its why I am being a little bit flip to encourage to OP to tell us what they can as literally at this stage the problem is too wide.
Didn't mean to offend - we are all all trying to help one another.
I have a special interest in fuel injection cars
FS
Posted 11 June 2020 - 10:21 PM
I then left the car for a few hours came back to it to go to the shop and it started I drove it out the garage and it spluttured a little and then died. I tried to start it again with no luck. Fuel is be injected into the bit below the air filter, I'm going to test for a spark tomorrow, but I cant see how I lost it if that is the case.
Posted 12 June 2020 - 01:44 PM
Edited by humph, 12 June 2020 - 01:45 PM.
