Help With Tv Pcb Fix
Posted 18 June 2020 - 12:32 PM
Should look like this
Faulty one...
Posted 18 June 2020 - 12:56 PM
I think it won't as it's conductive so would short all the connectors together.Would this do it.
https://www.amazon.c...g/dp/B00SRIITQ4
Posted 18 June 2020 - 01:45 PM
Posted 18 June 2020 - 03:06 PM
You can re-attach the cable using an anistropic conductive adhesive tape & some specialist expensive equipment to apply the correct pressure, temperature, & duration to cure it.
It's the preferred (ie cheap & quick) method of cable attachment for TV manufacturers & TV repair specialist will merely replace the whole screen/cable unit.
Oh poop! -I only started researching this as i've got the same problem on my old TV which i prefer to my new expensive one.
Hang on lads -i've got a great idea
(so don't ditch it yet, i will get back to you after a bit more research later on today).
Posted 21 June 2020 - 08:31 PM
A few hours has somehow turned into 3 days.... & i've failed (mine's gone at both the pcb AND screen end so it's definitely BER).
On the PCB end i thought there might have been a heat-resistant board edge clip for some application or other that could be used to physically hold the cable down onto the contacts but i've failed to find anything yet.
