Restoring a 68 Traveller.
The heritage outer sill has a large 25mm round hole in it towards the rear. Between the crossmember and the rear arch.
The hole looks like a Jack point hole. But it can't be as the traveller van etc used a different jack to the saloon and I cannot find any reinforcing gusset to fit behind here shown in any catalogue. Also the hole in the sill has no strengthening plate like it has on the saloon... so certainly not a jacking point.
So what is the hole for?
Anyone with a traveller or van.... what's in the hole... is it open or something in there behind it?... does it have a grommet... what was fitted there from the factory.. does anyone know???
Traveller And Van Outer Sill.
l7jnd
, Jun 20 2020 06:47 AM
2 replies to this topic
Posted 20 June 2020 - 06:47 AM
Posted 20 June 2020 - 07:27 AM
on a pickup there's a drain tube from the load bed that runs down through the hole
Posted 20 June 2020 - 07:32 AM
Thats great.... yes there is.. you are right. I hadnt realised. Now do i weld tge hole up or keep it... i want it as iriginal as possible. Did the travellers sbd vans have the drain hole from tge factory????
