Brake Master Cylinder Cap
7 replies to this topic
#1 jn1702
jn1702
  • 168 posts
Posted 20 June 2020 - 08:50 PM
Hi I have a 1993 Mayfair with a missing Brake master cylinder cap. Can anyone point me in the direction of a new one that would be original to the car. Many thanks
#2 Globule
Globule
  • 1,134 posts
Posted 20 June 2020 - 09:00 PM
Have you got a photo of the type of master cylinder? Being 27 years old it is possible it has been changed so you may end up with the wrong item if not careful!
#3 absx2
absx2
  • 961 posts
Posted 21 June 2020 - 09:14 AM
1988 on servo cap https://oldskoolmini...009-austin-7g5/
with the two spades should be what you need.
#4 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 21 June 2020 - 11:35 AM
The MPI type also fit the green type cylinder
#5 beardylondon
beardylondon
  • 1,817 posts
Posted 21 June 2020 - 01:03 PM
I needed to replace my brake cap recently, I had the grey type as per the lefthand photo below.
I messaged some of the sellers on Ebay, as I wanted to make sure I bought a genuine AP/920E part, as the manufacturer of original AP part is now called 920E. I received the right hand side cap from Minimine, and it was indeed genuine in a 920E box.
All the Ebay sellers I contacted said that the ones that looked like the below link are a copy, and not an AP part. I presume they work fine, but I have no experience of this cap, others may have more info.
Edited by beardylondon, 21 June 2020 - 01:05 PM.
#6 steeley
steeley
  • Just Joined
  • 623 posts
Posted 21 June 2020 - 02:34 PM
This is the one that I bought for my 84 Mayfair, it fits the yellow tag cylinder
#7 steeley
steeley
  • Just Joined
  • 623 posts
#8 absx2
absx2
  • 961 posts
Posted 21 June 2020 - 03:49 PM
Description
Classic Mini Brake Master Cylinder Cap & Float Switch
This is the original type master cylinder cap with the terminals on either side for the GMC90376 and GMC227 master cylinder. It has the spade terminals on which is for your brake fluid safety warning.
Part number for reference: GRK6009 (AEU1796).
