Valve Guide Seal
9 replies to this topic
#1 croc7
croc7
  • 894 posts
Posted 21 June 2020 - 04:19 AM
All 8 locations or just intake? Some have said the exhaust valve stems need a little lubrication.
#2 Spider
  • 15,840 posts
Posted 21 June 2020 - 06:29 AM
All 8.
Oil on the Exhaust Valve stems can burn and so wear the stems & guides, also on the Exhaust Valve Seats will pit them real bad.
#3 imack
imack
  • 2,381 posts
Posted 21 June 2020 - 06:40 AM
All my heads have only ever had them on the intakes.
My latest head from MED only has them on the intakes too.
#4 whistler
whistler
  • 1,894 posts
Posted 21 June 2020 - 08:00 AM
As Moke said.
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 21 June 2020 - 09:03 AM
Fit them on all 8 valves, also make sure you fit the MPI type
#6 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 21 June 2020 - 09:19 AM
For anything Road going fit 8, for anything boosted or high output NA I only fit them on the inlets.
Phil.
#7 Ethel
  • 26,789 posts
Posted 21 June 2020 - 03:26 PM
What's the reasoning with boost, Phil?
#8 andyapanel
andyapanel
  • 651 posts
Posted 21 June 2020 - 04:05 PM
I use the uprated Minispares ones on all 8, but only because I take all the valves out when I decoke a head.
I understand the argument for only doing the inlets, but if you have got that far stripping the head, what the hell, they can't do any harm.
#9 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 21 June 2020 - 09:31 PM
Temperature, the exhaust valves need all the lubrication they can get.
Phil.
#10 Ethel
  • 26,789 posts
Posted 22 June 2020 - 07:24 AM
I wonder how much oil pressure differentials will allow when you're on boost? Though there could be all sorts of Bernoulli weirdness going on too.
