Decent Exhaust For Quietness And Performance
17 replies to this topic
#1 MinesRed
MinesRed
  • 116 posts
Posted 21 June 2020 - 05:57 PM
Good evening all.
My 1275 stage 1 mini has a straight through exhaust,could be an RC40 but not sure.
At 3000rpm the noise in the cabin is too much,even with my ear defence.
As a sufferer of tinnitus which is aggrevated by the cabin noise can anyone recommend a decent exhaust,not too loud and one that won't affect the minis performance.
Thanks..
#2 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 21 June 2020 - 06:20 PM
Good evening all.
Thanks..
Twin box RC40 system
#3 gdcarpenter
gdcarpenter
  • Just Joined
  • 43 posts
Posted 21 June 2020 - 07:58 PM
For what it's worth: My Mini Mayfair 1000 Genuine 1990 Japanes Cooper conversion, so similar to stage 1.
Had an LCB, gutted CAT, single box RC40 when I got it, couldn't bear the metallic high pitched drone at highway speeds.
Now have stainless steel flex pipe, with an O2 sensor, LCB to the gutted CAT I kept, that may loose me a tiny fraction of HP, but so be it.
That's followed by a 1 3/4" Manjflow twin box, side exit. This set up is not a whole lot quieter, but the tinny high pitch drone is gone. It seems to me the Maniflow seems to be heavier gauge and more solid construction , which. I think, helps reduce the tinniness. It now has a deeper throatier sound that I can live with. The deeper sound may by less aggravating on your tintinitus.
All the best.
#4 leyland73
leyland73
  • 158 posts
Posted 21 June 2020 - 08:01 PM
Twin box rc 40, also using the standard air filter box with a k&n filter element is far quieter than a cone filter, less induction noise
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 21 June 2020 - 08:06 PM
Yes I agree with using the standard airbox
#6 evoderby
evoderby
  • 94 posts
Posted 21 June 2020 - 09:04 PM
Is your current system twin box or single box? Is the exhaust manifold an LCB or cooper type?
When it comes to performance without noise a Cooper type manifold fitted with a twin box RC40 side exit is about as good as it gets.   Fitting a turbo quietens things down even further whilst of course increasing performance, at the same time allowing you to select a taller final drive to reduce revs at cruising speeds and further quieten things down. As others have said, don’t overlook the air filter and last but not least dynamat, dynamat, dynamat!
#7 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 21 June 2020 - 11:33 PM
maniflow 1.75'' twin box side exit, cooper freeflow manifold.  :shades:
#8 nicklouse
  • 19,063 posts
Posted 21 June 2020 - 11:43 PM
how old is the current exhaust? side or center exit?
#9 Wazzah
Wazzah
  • 142 posts
Posted 22 June 2020 - 12:10 AM
Changed from centre exit to side exit which improved the droning.
Pulled the dash the other day and ripped out the factory sound deadening which weighed a tonne and replaced with dynamat.
Improvement.
Dynamated the under of the bonnet.
More improvement.
The engine driven fan annoys me the most and is very loud.
#10 leyland73
leyland73
  • 158 posts
Posted 22 June 2020 - 06:34 AM
[quote name="Wazzah" post="3654636" timestamp="1592784618"]Changed from centre exit to side exit which improved the droning.
Improvement.
More improvement.
The engine driven fan annoys me the most and is very loud.[/quote
Great progress so far, what air filter is fitted? Under bonnet sound deadening helps too
#11 MinesRed
MinesRed
  • 116 posts
Posted 22 June 2020 - 08:24 PM
It's got a manifold lcb manifold and straight through to read centre exit box.
The induction is via a pipercross cone,but I don't mind the sound of that.
#12 nicklouse
  • 19,063 posts
Posted 22 June 2020 - 08:33 PM
most of the noise should be coming from the carb with that set up.
so a single box set up change to a twin box and a side exit is quieter again.
and again how old is the silencer as they do blow the wadding out and either replace or repack if you can.
#13 MinesRed
MinesRed
  • 116 posts
Posted 22 June 2020 - 08:49 PM
That should read maniflow..
#14 MinesRed
MinesRed
  • 116 posts
Posted 22 June 2020 - 08:52 PM
Ahh right,so the airfilter contributes to the noise of the exhaust,I honestly didn't think it would,every day n all that...
Edited by MinesRed, 22 June 2020 - 08:53 PM.
#15 fokko
fokko
  • 195 posts
  • Local Club: Mini Seven Club Nederland
Posted 22 June 2020 - 09:04 PM
I agree to @evoderby. The exhaust pipe and its mufflers don’t contribute that much to interior noise. Most of the noise comes from induction sound (air filter & carb) and the exhaust manifold. The original cast manifold is the most quiet solution. An LCB (http://minispares.co...t/C-AEG365.aspx) is noisier than the Freeflow (http://minispares.co...t/C-STR816.aspx) manifold. Fit some good sound deadening to your bulkhead and decide which compromise you want to make; power or quietness.
