3 Clock Cooper Voltage Stabiliser
7 replies to this topic
#1 Austinretro1979
Austinretro1979
  • 280 posts
Posted 22 June 2020 - 07:59 AM
Hi all.
My temp gauge is not working properly and only climb to half distance between cold and middle. I have grounded the cable and it climbs all the way to the top. So I’m thinking it’s the voltage stabiliser. I have the 3 clock setup (Cooper) in the picture but I do now that the volt. Stabiliser is printed onto the board behind. I have read in another post that you can solder a solid state voltage stabiliser onto the printed circuit. Anyone done it ? Any guidance would be really helpful.
Edited by psoutzis, 22 June 2020 - 08:02 AM.
#2 slidehammer
slidehammer
  • 1,205 posts
  • Local Club: LSMOC
Posted 22 June 2020 - 08:33 AM
I would start by checking either the thermostatic isn't stuck open (indicated by the engine taking a while to get to temperature) or the temperature sender unit isn't faulty. I would have thought the voltage stabiliser takes care of fuel gauge as well and that would be playing up.
#3 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 22 June 2020 - 08:48 AM
I did this little 'mod' to fix our mpi fuel/temp gauge error.
http://www.theminifo...ge#entry3576145
seemed to sort my reg problem
#4 Tornado99
Tornado99
  • 750 posts
Posted 23 June 2020 - 04:45 PM
Can you describe what your issues were before this fix? I'm seeing what appears to be low temp readings but fuel gauge seems ok. If the regulator was bad wouldn't both gauges have problems?
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 23 June 2020 - 05:41 PM
If the voltage stabiliser was bad both gauges would be out. Get a thermometer and verify the guage, then check what temperature thermostat is fitted, my guess is a 74° currently
#6 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 23 June 2020 - 08:24 PM
yes in my case both gauges were 'out' ...
#7 Tornado99
Tornado99
  • 750 posts
Posted 23 June 2020 - 09:11 PM
Sounds like good checks to do. My dash temp gauge has non numeric scale...roughly at what temp should the first & middle scale marks above the blue mark be at?
Also, can the thermostat be checked without having to drain coolant?
#8 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 24 June 2020 - 06:55 AM
When the engine is cold you can check the thermostat. Just run the engine and keep checking the radiator top hose, it should stay cool as the engine heats up. Then if the thermostat is working correctly it should open once the engine is at normal temp, and the hose should start to get hot. If it all heats up at the same rate, thermostat is likely stuck open.
