Top Engine Steady Removal
6 replies to this topic
#1 Mayfair'93
Mayfair'93
  • 29 posts
Posted 22 June 2020 - 12:23 PM
Hello everyone,
I'm afraid I have a very basic question but it is something I've been struggling with all weekend!
I have a 1993 Mayfair 1275cc carburettor.
I'm replacing the top engine steady bushes. The bracket and steady have come away from the block just fine. I have removed the nut and washer from the bolt fixing the steady to the clutch master cylinder mounting plate. I can't however remove the bolt from the steady to release it. The bolt will spin but won't pull out. I can't get anything underneath the mounting plate to knock it up and out and I can't get purchase or leverage on the bolt head to lift it up.
Am I missing something? Any tips on drawing the bolt up and out?
Cheers,
E.
#2 blacktulip
blacktulip
  • 6,231 posts
Posted 22 June 2020 - 12:34 PM
These bolts are always giving grief. The issue is that the inner metal sleeve of the Bush corrodes and thus the bolt gets stuck. I have had this issue a few times and the best way I found was to just hacksaw the head of the bolt off under the top of the bulkhead plate using one of those hacksaw blades in a handle jobbie. Takes a while.
#3 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 22 June 2020 - 07:56 PM
It was a while ago, but I think I ended up using Mole Grips and wiggling it as I pulled up on mine.
It was awkward as the earth strap and mounting plate didin't leave a lot of room to get the jaws in.
You can try levering the steady bar itself up to expose a few mm more of bolt head.
#4 whistler
whistler
  • 1,894 posts
Posted 23 June 2020 - 07:56 AM
I use a junior hacksaw to saw through the bolt/sleeve where the rubber bush meets the top and bottom plates. That way you don't damage the mounting plates. Fit new bolt, rubber and sleeve.
#5 Mayfair'93
Mayfair'93
  • 29 posts
Posted 26 June 2020 - 07:22 PM
Thanks for all the tips. I'll give it another go this weekend.
#6 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 26 June 2020 - 08:28 PM
If the bolt turns, you could try some penetrating fluid, you might just get lucky but leave it soak for days not minutes
#7 Tds76
Tds76
  • 87 posts
Posted 26 June 2020 - 10:33 PM
I had exactly the same issue and ended up using a hacksaw blade between the rubber & upper plate. I also put some anti-seize around the new bolt when re-assembling.
Edited by Tds76, 26 June 2020 - 10:35 PM.
