Bonnet Pins
3 replies to this topic
#1 andyboy!!
andyboy!!
  • 365 posts
Posted 24 June 2020 - 03:05 PM
Hi
I’ve had some bonnet pins fitted. The bonnet fits fairly snuggly onto the body. Do I need to put anything between the bonnet and body - protection wise - seals, padding etc?
Andy
#2 GraemeC
GraemeC
  • 7,474 posts
Posted 24 June 2020 - 03:48 PM
I put some beading down the sharp edges of the bonnet so it doesn't rub the pain in the gutter away too quickly (it still will, but not as badly).
You could put closed cell foam in the gutters, but if it is too thick it will lift the bonnet up slightly
#3 andyboy!!
andyboy!!
  • 365 posts
Posted 25 June 2020 - 12:44 PM
Thanks GraemeC
Did you fit these to the body or the bonnet itself?
Reread your post and now it’s the bonnet now! ?
Andy
Edited by andyboy!!, 25 June 2020 - 12:45 PM.
#4 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 25 June 2020 - 01:02 PM
i have fitted a small amount of rubber heater pipe onto the upstand of the pin. then the bonnet sits ontop of the rubber.
