Diff Output Shaft Freeplay/wobble
5 replies to this topic
#1 Benito_S6
Benito_S6
  • 89 posts
Posted 25 June 2020 - 09:56 AM
Taken engine out to repaint and have noticed a free play in the diff output shaft. Have read that it could be fibre thrust washer, bronze bush in cover or a new diff could be needed. It’s worst on driver side as can be seen int video. Without stripping down, what’s people’s opinion on what it’s most likely to be? It drove fine with no clunks or knocks, only found out there’s owt wrong with it now it’s out.
Edited by Benito_S6, 25 June 2020 - 10:27 AM.
#2 Benito_S6
Benito_S6
  • 89 posts
Posted 25 June 2020 - 11:16 AM
I’ve uploaded it to YouTube as not sure if videos have uploaded right on here so they can be viewed.
https://youtu.be/25eHMcJLniE
Edited by Benito_S6, 25 June 2020 - 11:17 AM.
#3 GraemeC
GraemeC
  • 7,475 posts
Posted 25 June 2020 - 12:06 PM
The play in and out shows there may be some wear in the planet gear thrust washers.
The up and down play is expected as, without the pot joint that runs in the bush in the cover, there is nothing supporting that end of the output shaft.
#4 Benito_S6
Benito_S6
  • 89 posts
Posted 25 June 2020 - 12:30 PM
Brilliant Graeme, thanks a lot. With the very small amount of in and out play, is it excessive enough to warrant a strip down to change the washers to eliminate it all together? Might be worth doing so I know it’s perfect if it’s not a massive job.
#5 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 25 June 2020 - 12:39 PM
If I were you, I would refurbish the differential now before it s'plodes! I have some experience with that.
http://www.theminifo...al#entry2409082
#6 Benito_S6
Benito_S6
  • 89 posts
Posted 25 June 2020 - 01:54 PM
Something I am looking into doing now. Thanks
