How To Fit Original Glass Indicators To A 93 Car
8 replies to this topic
#1 I hate Brian
I hate Brian
  • 782 posts
Posted 25 June 2020 - 11:10 AM
How do you fit the glass indicators to a 93 mini ? they have three small fixing holes and the 93 has two square holes ?
#2 unburntfuelinthemorning
  • 2,003 posts
Posted 25 June 2020 - 11:19 AM
Drill three small holes to suit.
#3 I hate Brian
I hate Brian
  • 782 posts
Posted 25 June 2020 - 02:57 PM
I get that  but the rubber doesn't give me much faith holding the glass, as I expect you cant drill through the metal bulb holder ?
#4 mab01uk
mab01uk
  • 13,074 posts
Posted 25 June 2020 - 03:05 PM
Metal bulb holder should have a large flange with 3 holes in like this:-
http://www.minispare...62.aspx|Back to
You can also get the same style lens in later plastic version if you prefer.
Edited by mab01uk, 25 June 2020 - 03:06 PM.
#5 MikeRotherham
MikeRotherham
  • 1,030 posts
Posted 25 June 2020 - 03:21 PM
"I get that  but the rubber doesn't give me much faith holding the glass"
I seem to remember there was a chrome ring that you installed after the glass that embedded in the rubber and held the glass more securely or have I made that up? It was 1972 after all O_O
Edited by MikeRotherham, 25 June 2020 - 03:22 PM.
#6 I hate Brian
I hate Brian
  • 782 posts
Posted 25 June 2020 - 05:10 PM
No you are quite correct Mike it does have a chrome retaining ring
#7 SolarB
SolarB
  • 1,406 posts
Posted 26 June 2020 - 04:51 PM
I too was suspicious that the rubber and metal ring is the only thing holding the glass, but it works.
6-7 years after fitting them they have never fallen out.
Edited by SolarB, 26 June 2020 - 04:53 PM.
#8 I hate Brian
I hate Brian
  • 782 posts
Posted 26 June 2020 - 06:42 PM
Even offering spire clips up they don't seem to line up or have enough metal to fix to (genuine minispares indicators) after speaking to Minispares today !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#9 I hate Brian
I hate Brian
  • 782 posts
Posted 30 June 2020 - 09:09 AM
Problem solved used some tough nylon board drilled two sets of holes to make a big nylon washer then self tapped into the washer all good and tight
