Wiring To Fuse Box
4 replies to this topic
#1 steeley
steeley
  • Just Joined
  • 623 posts
Posted 25 June 2020 - 08:48 PM
Re fitted loom and I thank all is good with one (hopefully) exception, on terminals 7 and 8 has red to 7 and two red and greens to 8 there is also another connection with is unmarked for colour but it looks like it should be blue and white, I can’t find a cable anywhere that would go onto that fuse
#2 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 25 June 2020 - 08:59 PM
The proper wiring diagram and fuses covered are in the FAQ section
http://www.theminifo...a/#entry2766127
#3 steeley
steeley
  • Just Joined
  • 623 posts
Posted 25 June 2020 - 09:32 PM
It’s the one I’m working from, 84 multi instrument on terminal eight on the diagram there is a wire shown
Coming horizontally out between the two red and green what colour should it be it’s not marked but it joins into blue and white
#4 GraemeC
GraemeC
  • 7,476 posts
Posted 25 June 2020 - 09:57 PM
I think that could be a mistake in the diagram.
connecting a UW there would put the main beam on when the light switch is in the sidelight position.
The connection is not shown on the other ‘84 diagram and that should be no different with respect to the lighting wiring.
Edited by GraemeC, 25 June 2020 - 09:59 PM.
#5 steeley
steeley
  • Just Joined
  • 623 posts
Posted 26 June 2020 - 05:05 AM
thanks, i have just printed off the other 84 diagram with single cluster
Edited by steeley, 26 June 2020 - 05:05 AM.
