Carb/intake Connection
6 replies to this topic
#1 croc7
croc7
  • 895 posts
Posted 28 June 2020 - 03:59 AM
Installed a HIF44 on a new Maniflow intake and now the base of the carb interferes with the brake lines below the speedo opening on the firewall. Probably would work ok on a 998 block but not on the taller 1275 A+. I think I may be able to get enough room if I don’t use the 1/2” spacer between the carb and inlet. Anything drawbacks to bolting the carb directly to the intake, not using the spacer?
#2 Ethel
  • 26,811 posts
Posted 28 June 2020 - 06:26 AM
The throttle mechanism hitting the manifold.
#3 nicklouse
  • 19,066 posts
Posted 28 June 2020 - 09:18 AM
Use an adjustable engine steady to tilt the engine forward Or change the subframe to the later one that moves the engine forward 1/2”
#4 croc7
croc7
  • 895 posts
Posted 28 June 2020 - 06:41 PM
I've heard about tilting the engine forward.  Does that affect shift linkage alignment or wear on engine mounts?
#5 nicklouse
  • 19,066 posts
Posted 28 June 2020 - 06:52 PM
well it is that or re drill the subframe. people have been doing it for years. your biggest issue is the exhaust.
#6 croc7
croc7
  • 895 posts
Posted 29 June 2020 - 01:04 AM
On second thought, I’ll stick with the mini spares inlet.
Thanks all for the replies.
Edited by croc7, 29 June 2020 - 06:41 PM.
#7 Icey
Icey
  • 1,585 posts
Posted 29 June 2020 - 10:35 AM
I had to do this and a word of caution if you use an 'ultmate engine steady' type thing to push the engine forwards - if you don't re-enforce the studs on the bulkhead, it'll fatigue and fracture the metal around them. Mine did it and I've since read of it happening elsewhere too. I now have extra steel plates on either side of the panel.
Not having a spacer between the carb and the manifold does cause the mechanism to foul but it doesn't take much fettling to make enough room for everything to move around without issue.
Edited by Icey, 29 June 2020 - 10:35 AM.
